Hi,
I have an old propane tank to build a forge with. I need to remove the opd valve. Two internet sources suggest I heat up the tank's valve threads with a heat gun. Is that reasonable?
Btw: I am reasonably certain the tank's depleted...
--jason
Hi,
--jason
That is what I do. I drill a hole before heating it.
Wayne Coe
Artist Blacksmith
Sunbright, Tennessee
423-628-6444
waynecoe@highland.net
www.waynecoeartistblacksmith.com
“What do you most value in your friends? Their continued existence.”
― Christopher Hitchens
I'm curious. Why drill a hole? I open the valve all of the way...
My son is the Blacksmith
We've had several discussions here regards using old propane tanks as a forge shell. Generally the advice is don't. An empty disposable party balloon tank (helium) is a far safer and less problematic option.
Good Morning,
Pick a place where you can bolt a plate to the floor. Weld two tabs (with holes in them) on the plate, so you can put a bar through the holes in the base of the tank and through the tabs. Now the tank won't spin!!
Use a pipe wrench to grab the valve, you are not saving it so don't be friendly with it (cut off the safety shield if you want to). Un-thread it, counter-clockwise. If the valve is open, you won't get a surprise!!!
I made a socket (an ugly looking socket) to undo the valve with my 3/4" impact gun. No survivors, take it out.
As long as we are above our shoes, We know where we are.
Cutting open a propane tank is extremely dangerous. Even with all the gas out of it propane tanks can have a wax residue in them that is highly explosive. There was a kid killed at a school down east a couple months ago cutting open a barrel that had held Mint oil. He was using a zip cut, a was going to make a BBQ for a shop class project.
Years ago someone suggested I flush out my 100lb tanks with water prior to cutting them apart to build a tumbler. I waited until late in the evening to purge them because of the rank smell. So much skunk-oil came out someone called the fire department the next morning and they shut down the whole block! Fortunately I wasn't anywhere near the place, only showing up later in the afternoon!! Hee!
They only remember you when you SCREW UP~!!!
Hi Steve,
Was the skunk-oil the waxy buildup Daryl mentioned?
I think given the risk, I will just take the tank to suburban or ferrelgas, float the tech some cash and have them remove the valve. I don't think it's worth it otherwise.
--jason
This video has some pretty informative data........course the tanks they shot at were FULL and not mixed with air, which the mint oil barrel certainly was, wish I could be paid to have that much fun!
MythBusters: Propane Peril MiniMyth : Video : Discovery Channel
