Greetings to the membership, the following is the thread mentioned in the Three Scroll Trivet article in the third quarter 2011 issue of the HIN. I would like to apologize for not getting this up on an earlier date. The full sized jig is posted below in a PDF format. Print the jig on standard printer paper, then bend the flat bar into shape to mach the drawing.Then weld the jig to a length of angle iron so you can clamp it in your vice. Thank you for your patience.
Respectfully
Ben Czyhold
