I just completed a new propane forge build using John Emmerling's burner design from the Hammer's Blow 2006 article. I'm using a Dayton blower, 1/15 HP, 1530 rpm. Based on observing the forge at the 2009 Fall Conference, that forge had significantly more volume and pressure than my blower produces.
With my burner on top requires 2" plumbing with two ells separated with an 8" nipple, then coming down with 12" nipple coupled into the 8" nipple with gas 1/4" ell inside with .035 orifice (per John Emmerling recommendation), coupled to the gate valve and finally the Dayton blower.
Is my distance from gas and air assembly to far from the burner? Is my blower w/ motor undersized?
I need some recommendations and or suggestions please. Anyone's help would be greatly be appreciated.
Thanks, Rick
