I have old worn pick that is dulled. I'd like to re-point it. What I'm thinking of is removing a small amount of the worn metal at the ends (maybe 1/2" ?)and then re-pointing the tips at the anvil. Does that sound reasonable? And if so, how should I harden and temper it?
I'm thinking of treating it like a cold chisel, water or oil quenching the tip (1-1/2" or so) for a few seconds and then letting the colors run out to bronze at the tip, then quenching cold. Would that do? What would you do?
It's an old pick of good but unknown steel type.
