I am in the process of not only building the shop but equiping it with everything. so I am thinking up the forge. I have read that steel burns up quickly and has to be replaced. so I dont have axcess to a cast iron fire pot so I thought that a cast Iron sink that is 8" deep and 16" x 29" would work I could srink the size down by using furnace cement. and it could fit into the larger work forge I plan to build from a dock plate. or would the furnace cement make the 1/2" steel last as long as the cast iron??
