Results 1 to 8 of 8
Thread: first forging
    first forging
    Finaly got the forge fired up after a hickup with the fan and made my first thing today. Got the fire going after a few tries and stuck in some rebar. Kept burning it off but got a heart pounded out like Brian showed.
    What you see in the pic is about 3 hours work with getting set up and the fire started. Tomorow we fire up agean and the kids get to try.
Name:	10 13 11 Haseebs home 005.JPG
ID:	4095   Click image for larger version.
Name:	10 13 11 Haseebs home 006.JPG
ID:	4096   Click image for larger version.
Name:	10 13 11 Haseebs home 007.JPG
    Mike R
    Central Oregon
    Nov 2010
    Missouri
    Great job!
    Do you have an air gate to control the amount of air going to the fire? That fire looks pretty large in the photo. You'll find it doesn't take much blast to keep a good hot fire going, especially for smaller work, and with a little water you can keep a small fire that's incredibly hot. Going full tilt all the time will lead to melted steel and wasted fuel
    You'll have an easier time starting a fire now that you have some coke ready to go. Green coal can can be difficult to get going. Controlling the fire will come with a bit of experience.
    Good luck and be safe!
    Jim
    cool!
    JimB I do have an air damper on the intake side. The pic was taken as I got the fire going. I figured out to shut of the fan between heats and dampered down. I think I started with too much caol and too big a fire. I did start using a little water around the edges as I went along also.
    As it burned down and got smaller it was easier to control but had some problem getting the long rebar to lay in the fire. I may put some thin brick in the bottom and make it shallower.
    Mike R
    Central Oregon
    Mar 2011
    Maple Valley, WA
    Great start, Mike!
    Nov 2010
    Missouri
    Right on Mike.
    Just be careful that you don't make the fire too shallow or you'll experience severe oxidation since the incoming oxygen doesn't have time to be consumed before it reaches the work.
    Just make sure you keep raking fuel up onto the fire and pushing the coke into the heart of the fire. It's an ongoing process so it's best to develop a consistent method early and get in the habit of doing it.
    Can't wait to see what you forge next.
    Jim
  7. kudos
    Hey dere;
    That's a fine job I should start with one of them. Looking forward to firing up the forge as well.
    all the best
    Quote Originally Posted by Mike Reinemer View Post
    Hey Horvic the hearts are lots of fun. My daughter enjoyed making one. Show a pic of how it goes. I got it from Brian Brazils how to pics on IFI by the way. I think he did a vidio on them also.
    I have made a few more and seem to be getting a little better control of the hammer and the fire.
    We got some time yesterday and I tried upsetting and made a ball on the end of digger chain. Anthony made a double hook as a something to throw. He stayed at it for about 2 hours so I thought that was preatty good for an 11 year old.
    Thanks for the comments
    Mike
    Mike R
    Central Oregon
