Results 1 to 5 of 5
Thread: SUNBURST
    Jan 2011
    johnstown,co
    SUNBURST
    1/4" Steel plate "'rays" convoluted in the ph with an upper 3" ball die and a lower cup die. The center is an 8"dia x 5" hole x 8" long bit of tube. An upper "corner'' die was hammered into the top of the edge............7 ft dia, 8 in. thick, 140 lbs. .......bm
    I like it Bruce.. Was it a commission or just a play thing?
    What's the finish? 8"x8" what did you hit that with? Cool piece.
    Jan 2011
    johnstown,co
    Quote Originally Posted by Larry L View Post
    I made it for fun, and hopefully profit.......It might be nice on a on a key chain........
    Jan 2011
    johnstown,co
    Quote Originally Posted by Danger View Post
    The finish is just brass aerosol from ace. The paint has since had a gun blu wash patina, for those of who don't know, most brass paint can take a patina .Hoisting that bad boy up for an updated pic was too much,sorry.
    The 8"x 8" cyl was forged with the "corner" die, d1. The "corner" faces front when used. I had to weld a handle every 33 deg. and work 3 divets at a time, a bit labor intensive.
    The ball and cup are what they are.............bm
ID:	2063   Click image for larger version.
